Infinite
1 year agoNeighbour
Delay Connecting To Internet - Wired Connection
I recently had Fibre installed in my home and signed up for a plan with Telus. Everything is great except my PC connected to the router takes about 30 seconds to achieve a connection. I can only assu...
1 year agoHero
This post by FuzzyLogic seems to describe the same issue you are facing:
"I also use the ethernet ports on the AP and they work fine but seem to 'hibernate' if not used for a while and take a bit of time (~30 seconds) to wake when the device connected to them is turned on."
Infinite
1 year agoNeighbour
Sure but it does me no good if there isn't a solution. The only fix I can find online is to plug in to the gateway and not the router. Cable shopping I go, I guess.
