Esto
4 years agoOrganizer
Wired Telus Boost
Hi there, this seems like a simple question, but I can't find a firm answer: is it possible to connect via ethernet a secondary Telus Boost device? I managed to run a long ethernet cable from th...
- 4 years ago
Try accessing the web interface on the Boost units vis their assigned IP address, rather than through the App, and set them up there.
4 years agoTry accessing the web interface on the Boost units vis their assigned IP address, rather than through the App, and set them up there.
Esto
Thank you, I had no idea this was possible. They are both working connected via Ethernet now.
Thanks again!
