eyestalk
6 years agoFriendly Neighbour
Telus Wi-Fi Hub re-enabling wifi despite being in full bridge mode?! DHCP chaos.
Hello All, First post here... have had Telus 750/750 for a week now. This morning (at about 3 am), it seems my Telus Wi-Fi Hub (white diaper genie style), re-enabled the WiFi services on it, de...
- 6 years agoSFP and SFP+ are not compatible hence why I mentioned the need for a media convertor.
You could also use a Ubiquiti Edge Router ER-X-SFP but it's got some issues with the Nokia SFP Telus uses and is not unifi.
With the media converter your simply converting the fiber SFP which is max 1Gbps to single 1Gbps Ethernet port you can just plug into your current hardware.
kevhawk
6 years agoOrganizer
eyestalk
Thanks. Will look into a media converter to eliminate the Telus Hub
Related Content
Home services cancellation fee applied despite special circumstances agreement
Last summer I contacted telus to renew our father in law's internet and home service agreement. I was offered a good plan but I explained, I'm the POA for a 91 year old senior with dementia. He likel...Solved200Views2Comments
