Justimus
4 years agoNeighbour
Telus TV+ remote control programming
Wondering if there is a way or if there is a pending software update so I can program the new Telus TV+ Google remote, to control volume via my AV receiver? Love the new service, just would like more ...
- 4 years ago
Hey Justimus! You may need to reach out to our Tech Support team for specific assistance with this, but we can offer the following info (it may or may not work for your particular receiver). We've got both a specific table with some brands, and a manual process.
Specific Brand
1. Find your AV receiver brand in this list:
- 1 Yamaha
- 2 Onkyo
- 3 Denon
- 4 Pioneer
- 5 Sony
- 6 Marantz
- 7 Harman/Kardon
- 8 Philips
- 9 Teac
- 0 Bose
2. Press and hold both the Mute key and the number key corresponding with the Brand ID you found above for 3 seconds. The green LED should stay on.
3. Press the right arrow key.
4. If your soundbar mutes, try the up and down volume buttons to test. If it works, press OK to save the settings and you're good to go.
5. If your soundbar doesn't mute, press the right arrow key until your AV receiver or soundbar mutes indicating a code has been found. If it's found, press OK to save the settings and you're good to go.
If that doesn't work, it may need to be set up manually which you can get our team at 1-888-811-2323 to assist with!
viperdiablo1
3 years agoAdvocate
Why would we have to call in to get the Samsung code? Can’t it just be posted here? Or do they do something special to the remote ?
A-B
Community Manager
3 years agoIt'd have to be manually done. I can leave the steps here, but two things to note:
1. Samsung has two codes that may work in the process, so it'd need to be tried with both to see if either works.
2. Due to the large range of amps and receivers, etc. we can't guarantee that this process will work so we recommend to just use the remote that came with the amp or receiver.
That being said, here are the steps to try:
1. Press and hold the OK and mute buttons on your Optik remote until the green LED light stays on.
2. Enter this three digit code: 289 or 117
3. If the green LED light blinks twice, you can test the mute button, volume up and down buttons, etc. to see if it works.
- viperdiablo13 years agoAdvocate
Would you happen to have any more Samsung codes. Those two don’t seem to work for my 3 year old Samsung q70r soundbar . Thanks
- A-B3 years ago
Community Manager
That's all the codes I have. If none of them work, it may still be doable via our Tech Support team who can look into manually connecting them. Give them a shout at 1-888-811-2323.
