ArneSalvesen
6 years agoNeighbour
ArneSalvesen
I've done that. Boost is one name, and the 5G from the router is another.
epikish
Hi, I'm having this exact same issue. Did you manage to fix it? It only seems to happen on some Apple devices. I have no problems with connecting on my android phone, but my macbook and sister's iphone keeps getting disconnected.
- botsauce6 years agoNeighbour
I have the same issue. The boost network worked fine for a bit, now my MacBook drops from the network and can't stay connected.
I'll update after I call tech support.
- epikish6 years agoNeighbour
Any luck??
So, I called Telus numerous time over the last month to try to resolve the issues. They sent a technician over twice. Each time they were able to configure the network in a different way and solve the problem temporarily, but this wasn't any better than what I could achieve on my on by resetting the boosts each time they went wonky. The thing is, I don't want to have to reset my network every few days. Before I got the boosts the network worked fine. Boost was supposed to make it great, but it did the opposite. So, the boosts are back in the box and headed for Telus. I'll wait for the next gen before trying again.
