mikejf's avatar
mikejf
Friendly Neighbour
2 years ago
Solved
NH20A Bridged = random dropped connection on wired
Hello,
I saw the r/telus and searched as much as I could online, Telus forum, and in Reddit for possible solutions.
Long and short, moved from Shaw to Telus on the 9th of May.
I have a homelab setup with a Pfsense router managing everything.
Shaw was setup bridged, so swapping out the Shaw modem with the NH20A in bridged mode should be easy peasy.
However, when it is in bridged mode, the connection drops randomly. Multiple times per hour, sometimes for seconds, sometimes for minutes. Longest run was 2.5 hours.
Phone support tried a variety of basic troubleshooting steps over multiple phone calls. Factory reset with bridge mode turned off works without any dropped connection.
Telus tech has come out after the install, and he didn't have any idea. He just verified everything was installed fine and checked the modem settings on the dashboard.
To clarify, all devices, throughout my network, all have cat5e connections. When directly connected to the modem with a laptop, and any PC on the other side of my firewall, and devices connected to the wifi thing, all forms of connections drop at the same time.
The lights on the modem and wifi thing stay solid green.
Any ideas?
Thank you for your help.
-Mike
  • I was recently reminded to come back here and update anyone who stumbles on this...
    Turns out ntop in pfsense was the culprit.
    I ran through a ton of trial-and-error, turning things off, testing, then on, and a bazillion forums trying to figure this out.
    One helpful little app in pfsense I hoped to use to filter and monitor web traffic, sometimes causes something to break exactly every 15 minutes.  I completely removed this, and it worked instantly - no more dropped connection.
  • mikejf's avatar
    mikejf
    Friendly Neighbour
  • NFtoBC's avatar
    Sorry, can't offer any suggestions, as I don't have the NH20A.
    What happens to connected devices on the non-bridged ports?
    • mikejf's avatar
      mikejf
      Friendly Neighbour
      Right now port 1 is bridged, wifi is on the 10G port, and I have a laptop directly connected to port 3.
      Only port 1 is set as bridged.  All devices experience the same connection drop at the same time, including the laptop on the non-bridged port 3.  Hopefully that makes sense.
      • WestCoasterBC's avatar
        WestCoasterBC
        CPU Alum
        Have you tried not setting up port 1 in bridge mode, generally we never set it up as it's not needing to be in bridge mode. How often are the drop outs?
