mikejf
2 years agoFriendly Neighbour
NH20A Bridged = random dropped connection on wired
Hello, I saw the r/telus and searched as much as I could online, Telus forum, and in Reddit for possible solutions. Long and short, moved from Shaw to Telus on the 9th of May. I have a homel...
- 1 year ago
I was recently reminded to come back here and update anyone who stumbles on this...
Turns out ntop in pfsense was the culprit.
I ran through a ton of trial-and-error, turning things off, testing, then on, and a bazillion forums trying to figure this out.
One helpful little app in pfsense I hoped to use to filter and monitor web traffic, sometimes causes something to break exactly every 15 minutes. I completely removed this, and it worked instantly - no more dropped connection.
2 years agoSorry, can't offer any suggestions, as I don't have the NH20A.
What happens to connected devices on the non-bridged ports?
mikejf
Right now port 1 is bridged, wifi is on the 10G port, and I have a laptop directly connected to port 3.
Only port 1 is set as bridged. All devices experience the same connection drop at the same time, including the laptop on the non-bridged port 3. Hopefully that makes sense.
- WestCoasterBC2 years agoCPU Alum
Have you tried not setting up port 1 in bridge mode, generally we never set it up as it's not needing to be in bridge mode. How often are the drop outs?
- mikejf2 years agoFriendly Neighbour
I asked the Telus tech installer set up bridge mode since my Shaw setup was also in bridge mode. I have my own network set up with Pfsense as the router to manage everything.
I also have a few web apps I run for my family's use only when we are away, and remote systems and VPNs for when I am working away from home.
So, I expected swapping out coax for fiber with bridge mode set up to be a simple exchange.
That all being said, if there is a better way to do this with Telus, where the modem's firewall allows all traffic through on every port I use, then I can still have the access I need for my work and my family and the level of security I prefer, under my control, I'll gladly accommodate.I appreciate the suggestions and questions you guys have thrown at me.
Have you removed the telus modem from bridge mode and tried port one without it active? Just to see if the issue persists?
