ArneSalvesen
6 years agoNeighbour
rc
6 years agoRockstar
Telus recommends that the boost have their own unique ssid.
- ArneSalvesen6 years agoNeighbour
I've done that. Boost is one name, and the 5G from the router is another.
- epikish6 years agoNeighbour
Hi, I'm having this exact same issue. Did you manage to fix it? It only seems to happen on some Apple devices. I have no problems with connecting on my android phone, but my macbook and sister's iphone keeps getting disconnected.
- botsauce6 years agoNeighbour
I have the same issue. The boost network worked fine for a bit, now my MacBook drops from the network and can't stay connected.
I'll update after I call tech support.
