ArneSalvesen
7 years agoNeighbour
Jammer005
7 years agoOrganizer
iPhone XR as well, most of my other Apple Devices seem to work ok. Intermittent - I'll look at my phone and see that it's off the wifi. Grrrrr. Often asks to enter password and it won't accept. Of course, I do the usual steps (forget network, airplane mode, soft reset, forget network settings) but usually rebooting the router works.
3 Wired (+ one wireless) booster with SSID separate from the router. In fact, router has hidden SSID for some of my 2.4 older devices that had couldn't stay on the Booster network (eg Nest Camera, Wemo, etc) and 5 Ghz turned off.
I think it has something to do with the boosters as I move around the house something likely glitches out.
Not sure if this is an Apple problem or Telus problem since it primarily (but not always) seems to happen on my XR.
