abcd
5 years agoOrganizer
Switching home phone from copper to fibre - installation question
I have Telus fibre installed at my house for internet and Optik TV, but am still on copper for home phone. I have a question about feasibility to use some existing in-wall ethernet cable to connect ...
- 5 years ago
An alternative would be if there is a coax jack in the living room. That could be used in place of the ethernet if there's a coax outlet in or close to the wiring panel in the basement. The ethernet jack in the living room could be repurposed for phone and a MoCA adapter could be put in the panel to convert the coax back to ethernet. The panel would have to be rewired for a bit for it all to work. The MoCA adapter does need power as well. Telus does have the MoCA adapters. If you convert your phone to fibre, I'd suggest talking to the installer.
Phone lines only use a single pair. Ethernet uses all four pairs if you want gigabit speeds. If you were OK with putting a bottleneck into your home network, you could drop down to 100mbit ethernet, or 1/10th the speed and use only two pairs. That would allow one of the unused pairs to be used for a phone line. If you are able to purchase and supply the wall plates it's possible the Telus tech could do it but there is a chance they could charge for it. There is an adapter you can buy where the wall jack would not need to be re-wired though I've never used one. The adapter doesn't require any rewiring, it's low cost and it's user friendly. Just plug in the cables.
I have a multi-handset cordless phone and what I've done with my ONT is I have plugged the main base station for that phone directly into the ONT and then just have the wireless handsets spread about. It works for me but my place isn't huge.
abcd
update - I think I'm going to move my cordless phone basestation into the living room so it can be plugged into the ONT.
I decided I don't want to limit that leg of my network to 100mbit - thanks again Nighthawk for pointing out all 4 pairs of the cable are needed for gigabit, and also for suggesting plugging the cordless phone basestation directly into the ONT.
One different question about getting home phone working on fibre - since I already have the fibre and ONT installed and working at my house, aside from plugging the cordless basestation into the POTS1 or POTS2 jack on the back of the ONT, does an installer even need to come here on-site, or can they simply enable something remotely to turn on that feature of the ONT?
polecat
5 years agoAll-Star
abcd Nighthawk My phone is on fiber ont with batt backup. Data cable from ont to 3200. Pots 1 cable from ont to wiring block for all house tel jacks. The incoming tel wires have been disconnected from the wiring block my jacks are all fed from the ont by way of pots1. I don't think you can use pots1 for phone if you are still using the copper. I think my copper line is also opened up at the tell pole. My tech had to go several time to a fiber cabinet 4 blocks away to get the phone to transfer over to fiber. Try a phone in the pots but i think its dead. Polecat
