grover19711
2 years agoNeighbour
Simple port forwarding issue with TELUS Wi-Fi Hub
The issue: When I add a new port forwarding setting and save it, it works for about 10-15 seconds before the setting changes to a different IP. The port does not change, the IP always changes to '.12...
Anonymous
2 years agoNot applicable
Dynamic ip address means the ip address always keeping on changing on the router, every time you reset the router or set dynamic ip address ip address by default setting.
You want to change to the setting on your router to a static ip address of 192.168.X.X, subnet mask of 255.255.255.0 and 192.168.X.X default gateway of your network.
I hope that helps.
