paulsanderson's avatar
paulsanderson
3 years ago
Solved
Problem with screensaver not working properly
Hello, I have the newer Telus Digital Box that uses the cloud. I'm just having a problem with the screensaver. I have it set to colours, to start after 15 minutes. But it always displays the other op...
  • paulsanderson's avatar
    3 years ago
    Oh, that explains it. I do see the informational screensaver first, but I thought that was the Backdrop one, since only it and Colours are named in the settings. I didn't know that was a custom default screensaver that comes on first. I'd prefer it just went straight to Colours or Backdrop then, but I guess that can't be changed?
    I also didn't know that the screensaver won't activate when something you're watching is paused. I didn't see that mentioned anywhere either.
    So it actually is working the way it's supposed to after all. Now I know! Thanks for your help!
