wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
soloyo
just have telus internet installed few days ago. Same issue, redlink internet led is yellow, and have not connections alerts.
The WIFI6 is a booster not a router so have nothing to do ith this. the issue is with the gateway/router.
Any solutions?
Pruthvi077
3 years agoNeighbour
Hi, just use TP Link network switch, attach with your router or anywhere the Ethernet cable available, and then Redlink attached to TP Link it should work.
Mine is working that way.
