wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
KRC
3 years agoFriendly Neighbour
Thank you for sharing these steps to connect Honeywell Redlink Internet Gateway with Telus Network Access Hub. It worked perfectly for me. Just to let everybody know that the IP 192.168.1.254 is for the Network Access Hub and not the Wifi6 Booster. So the Admin password for this IP is available when you open the cover of the Access Hub. Once you login with the right password and look the above mentioned steps, you will be good.
paulpooco
3 years agoOrganizer
ATTENTION TELUS: please fix this so owners of Honeywell Redlink Internet Gateway do not have to do a work around.
The device is not hacking anything.
