wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
soloyo
just have telus internet installed few days ago. Same issue, redlink internet led is yellow, and have not connections alerts.
The WIFI6 is a booster not a router so have nothing to do ith this. the issue is with the gateway/router.
Any solutions?
