wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
soloyo
just have telus internet installed few days ago. Same issue, redlink internet led is yellow, and have not connections alerts.
The WIFI6 is a booster not a router so have nothing to do ith this. the issue is with the gateway/router.
Any solutions?
- Pruthvi0773 years agoNeighbourHi, just use TP Link network switch, attach with your router or anywhere the Ethernet cable available, and then Redlink attached to TP Link it should work.
Mine is working that way. - paulpooco3 years agoOrganizerHow is the Honeywell Total Connect thermosat app for you? I find sometimes what th3 app shows is happening isn't what is actually happening. I.e. app would say cooling was on but is wasn't in real life.
- Dnice403 years agoNeighbourConnects and communicates well.
