mtwohig
7 months agoNeighbour
Power adapter issue on Telus TV Box
I have a couple of Telus TV Android boxes. One of them stopped working, just won't turn on. After googling I found the issue was likely the power cable. I tested it by swapping it for the power ada...
6 months agoWe've replied to your private message, thanks.
Rocky3
6 months agoGuardian
I thought I had already posted the link. I went to get it from past order and it is not available at the moment. Meanwhile I posted another thread where it appears Telus discovered the problem too and is sending out new power cables, which it appears are identical to the ones that fail.
- Rocky36 months agoGuardian
The one I bought is
Arkare 12V Power Supply 2A AC/DC Adapter 12Volt Wall Charger Replacement Power Cord AC 100V-240V to DC 12Volt 2A. It was black, now offered in white
https://www.amazon.ca/Arkare-Replacement-100V-240V-Converter-Security/dp/B0BRPZDST7
- PaulieEYYC6 months agoOrganizer
Is this the box you are talking about that is the problem? Will the adapter fit?
- Rocky35 months agoGuardian
Sorry for late reply, or maybe another post was deleted.
That is the box however that box now has two different power plugs. Original is round and newer is the type C usb
