giantbrownguy's avatar
5 years ago
Solved
Issues with Arcadian Wi-Fi Hub
Hey guy...been having a couple of odd issues with my Wi-Fi hub, and wondering if anyone has any suggestions.
1) I haven’t been able to run a speed test in the My Wi-Fi app for about a week.
2) I was trying to watching something on Crave on my iPhone today and the signal kept dropping. I know this because I was constantly getting a warning that I was using mobile data. This was happening whether or not I was moving. I have two Boost units in the house as well.
Tried restarting but it didn’t seem to help. Anyone else having issues?
  • I had this issue a couple weeks ago. I have 1.5gbs fibre and was getting speeds are 300mbs on wifi so I performed a manual factory reset on the wifi hub. After the reset, I could no longer perform a speed test through the telus wifi app as it said the device was offline. Spoke to a couple reps with no success and I had a tech come by but didn't do much to resolve the speed issues and the new issue of not being able to run a speed test.
    The solution that worked for me and got everything back to normal was to sign into Mytelus and change my internet plan from 1.5gbs to 1gbs, then after 10min or so, switch my plan again back to 1.5gbs. Then I re-installed the telus wifi app, registered the wifi hub again, and ta-da! Just a theory and not certain if my little workaround actually did anything, but may be worth a shot!
  • Do you see anything unusual in the Arcadyan system log?
    • giantbrownguy's avatar
      giantbrownguy
      Rockstar
      How do you get to the system log? I can't find a log in the web utility or in My Wifi.
      • xray's avatar
        Hero
        Sorry, I don't have that router. I just assumed it would have access to the system log with the Admin login just like my T3200M.
