Gras's avatar
Gras
Friendly Neighbour
5 years ago
Solved
Wi-Fi Hub Bridge Mode Issues.
Hi everyone,
New to Telus Gig today. Bridged the Wi-Fi Hub to Lan1 FULLY (as I don't have any other Telus services) Hooked up my AC68U (running Merlin) and I'm being throttled at 300 down and 300 up. If I revert directly to the LAN1 port via ethernet/direct connect to a computer I see about 900down and 750up. If I hook back up to my Shaw I have no issues pulling 650 down. Any thoughts?
  • Don’t forget that extreme network speeds are not a single path, but a form of multicasting. If your additional router is incapable of handling multiple streams, you will see the result you describe.
  • Hey Gras how did you put the Telus Wi-Fi Hub into bridge mode? (I assume you are running the Arcadyan AC Fibre and not the T3200M). Struggling to find guidance online - doesn't seem to have an option?
    Thanks.
    • Gras's avatar
      Gras
      Friendly Neighbour
      Hi 198SIX  I do have the Arcadyan! or Telus Wi-Fi Hub in disguise 😉  Guides are hard to come by for this. I spent the majority of my day being passed around between departments LOL! Literally 4 hours of my day. When I load the settings of the modem... Click on Network> then hover over LAN. Mine dropped down with 3 options... LAN/LAN DHCP/Bridge. Be careful if you have other services with Telus (TV, Security, Smart Home etc...) when adjusting to bridge mode. Hope this helps  🙂
      • TechWise's avatar
        TechWise
        Organizer
        Hey Gras,
        I was just wondering how did you fix your slow wifi on bridge mode? I having the same issues right now. I have 1 gig internet and am getting barely 80 mbps/80mbps on 2.4 ghz and about 300/300 on 5ghz. My setup is ONT > T3200m > Linksys EA9300. The T3200m is bridged with port 1 and wireless radio is off, letting the EA9300 handle the wifi. My speeds are way worse compared to what my t3200m was getting on wifi!
