BDiddy's avatar
BDiddy
Friendly Neighbour
4 years ago
Intermittent Connection and Disconnection on Pure Fibre after new modem, splicing, strong signal
At random intervals my purefibre internet completely disconnects and subsequently reconnects.
I have called tech support, had the modem replaced and resliced.  My work video calls are dropping and google home music disconnects.  It happens between 6-15 times per day.
I cant continue like this working from home. I paid for a dedicated 24/7 connection to the internet.
  • BDiddy's avatar
    BDiddy
    Friendly Neighbour
    Soo I have tried something different.  I changed the setting in admin, which I guess was searching for an optimal channel daily at 7 am in the morning.  I may change the time to a busier time of the day if it seems that I get more interference at that time.  So far today, things seem to be working much much better.  But only time will tell.
  • Hi BDiddy, did your issue ever get resolved? This sounds exactly like what I am experiencing...
    • BDiddy's avatar
      BDiddy
      Friendly Neighbour
      No, unfortunately it hasn't been resolved. It seems to be  VERY common issue. I posted about it on social media, and you should see the responses.  It is incredibly annoying.  I am a student, and I will be in my flow state working on a paper and bam, office 365 disconnects and freezes because of connectivity issues.  I can't even type a word when this happens.  I almost just bought Office student so I could work offline then I thought - why?  I am paying the equivalent monthly for internet - it should work!
      I have even at times installed a monitor to track the issue.  The last guy that came said I have had too many devices connected.  Give me a break!  its fibre optic and I live in a 600 square foot condo, its not like I am mining crypto or something.
      When you search social media A LOT of people are having this issue. Its a network issue - and if it doesn't get addressed soon - I am just going to cancel.
    • Which modem or router you are using and what is its firmware version?
      • BDiddy's avatar
        BDiddy
        Friendly Neighbour
        I don't know what firmware it is but it is the T3200M
  • Hi there,
    You may try factory reset the modem when it is possible.
    Also, what is the modem you are using and which firmware version?
    Thanks
    • BDiddy's avatar
      BDiddy
      Friendly Neighbour
      I've done this countless times-for good measure.  It gets so bad at times, I just connect to my phone because it is stable.
  • NFtoBC's avatar
    Keep a record of when this happens (date, time and length of outage) and call support again. The more info you can supply, the easier it is for them to fix.
