Natewr's avatar
Natewr
3 months ago
I power cycled my router and now there is no signal
Hi there. I have a fibre connection with a modem/router style box that has numerous ports on it.
long story short but I was trying to connect a NAS and they suggested I power cycle the router. I did so, and now I have no internet signal whatsoever.
I was on hold with support for 40 minutes and then they disconnected as it was past their working hours
any tips? Thanks 🙏
  • El-Eric's avatar
    El-Eric
    Hi Natewr​ - do you have the white square fibre box? Does it have a green light or a red light?
    Power cycling does not cause a loss of data so just make sure all the cables are snuggly inserted into the appropriate ports.
  • I have a modem, router, WIFI, Optik
    If you also have more than one beside router, turn them all off and then about a minute apart and in this order plug in modem, router, WIFI, OptikTV.
  • I should specify-
    the light on it is green and the ports are all flickering as usual. I can see the wifi connections listed, they just don’t have any internet connection.
