dbor
1 year agoOrganizer
Bridge mode and optik on Telus Wifi Hub
Hi, I have a T3200 in bridge mode and use my own gear for routing, DHCP, etc. I also have an Optik box that's plugged into a port on the T3200 and it works just fine. Telus just sent me the whi...
Pattydee3
1 year agoOrganizer
Do you have the old Arris Optik boxes or the new Android ones? Bridge mode works fine with the new Android boxes since they’re pure OTA, but the Arris boxes need to be on a non bridged connection. This is where the port selection in the NAH comes into play. Bridge LAN port 1 only, and connect your 3rd party router to it. Use LAN 2 to connect to the arris boxes, or the Boost AP if you’re connecting over wifi.
dbor
1 year agoOrganizer
Thanks for the info. When I realized that the ethernet ports were still only 1 Gbps I arranged for Telus to install an NH20A instead as it has a 10 Gbps lan port, and am no longer using bridge mode for anything.
