NoSmoke
3 years agoFriendly Neighbour
Telus Wireless Home Phone Issues
Hello all, I have just installed the Telus ZTE WF723A wireless home phone and while it mainly works well, it has issues with some of the features. For instance, I cannot get Conference Call to work....
- 3 years ago
Hi NoSmoke too bad you're having so much issues with the wireless home phone. From what I understand there is always a short delay before a command is completed. When doing a conference call for instance you place the 1st call once it is connected you either press the «flash» or «talk» key, there is a short delay for that command to happen and once you hear the dial tone you can dial the other line then once connected after the short delay press the «flash» or «talk» key to connect everyone.
For the call forwarding, there are also different types of call forwarding, depending on the one you choose you have to use the same set of commands to activate or deactivate
To extend the lenght to dial a number try this set of commands *983*238*XX# the last 2 XX's are for the lenght you want. For instance if you want 8 seconds, then the command would be *983*238*08#.
I hope these can work in solving some of the issues you may have.
Fabylous
3 years agoNeighbourhood Alum
Hi NoSmoke, I'm happy to hear there were other solutions that worked with your service. From what I can see the conference calling should be working, I wonder if this could be a configuration that needs to be applied to your service for it work as it should.
NoSmoke
I dunno what can be done about it. Telus seems to have run out of things to try (they "reset" stuff at their end and the ZTR has been reset, all to no avail). This is why I'm wondering if the Telus ZTE supported Conference Calling from the get-go.
The only thing left I can think of is to buy a new, more up-to-date hand set to see if it makes a difference.
