DylanFromCanada
4 years agoNeighbour
Bought open box Samsung S20 5G & Wi-Fi Calling will not work
I bought a Samsung S20 5G (Model SM-G981W) from a re-seller in Toronto as an open box product.
Everything works great except I don't have the option for enabling VoLTE under mobile networks in settings and when I try enabling WiFi Calling from the phone app settings it says requesting service, please wait... and then gives me an error message saying it cannot be set up, try again later.
Moved SIM card from my old S7 which is running a custom ROM of Android 10 and VoLTE & WiFi calling are both working fine.
The Galaxy S20 has the latest updates, firmware and software.
One UI 3.1
Android 11
Baseband Ver. G981WVLU2DUG1
Build No. RP1A.200720.012.G981WVLU2DUG1
Service Provider Soft. Ver. SAOMC_SM-G981W_OYV_TLS_RR_0012 TLS/TLS/XAA
Android Security Patch: July 1, 2021
- Tried taking out SIM card and putting back in
- Restarting and factory resetting
- Installing Google's "Carrier Services" app as suggested by Telus Tech Support
- Updating firmware on ODIN
This phone is listed on Telus site list "Eligible non-TELUS devices with Wi-Fi Calling support".
Any ideas or suggestions that I can try before I go through the return process?
- Nighthawk
Wifi calling requires VoLTE to be working.
https://www.telus.com/en/bc/support/article/wifi-calling-faq
Am I eligible for Wi-Fi Calling? You are eligible if you have an eligible device (see below) and an active
My TELUS subscription. Wi-Fi calling is not currently available for Prepaid as it requires VoLTE
for it to work, which is not yet available on Prepaid.You bought a device that was originally not sold by Telus and therefore will not have the Telus rom/firmware and isn't registered to work for wifi calling. To get VoLTE working, you will need to call tech support again to see if it's possible. No idea if it'll be possible or not. iPhones are easier because there is one OS on them. Android has so many different roms based on each device manufacturer and each device, individual countries and individual providers. It's a mess.
- DylanFromCanadaNeighbour
That might have been the case when I first received the phone but you would think after flashing the device (with ODIN) with the latest Telus firmware for my phone would have taken care of that problem.
https://www.sammobile.com/samsung/galaxy-s20/firmware/SM-G981W/TLS/#SM-G981W
Also, my old Galaxy S7 was never purchased from Telus. I brought it over from Bell when I switch to a BYOD plan at Telus many years ago and it has a custom ROM (Floyd) of Android 10 on it. VoLTE and WiFi calling work fine on that phone.
- Nighthawk
Unfortunately you're still going to have to speak with tech support. You'll need VoLTE first before wifi calling according to the support page. Simply swapping the firmware won't magically fix the issue. They'll also need to register your phone on the network to access VoLTE if they haven't already.
