The guide
BN
In the guides to the left of the channel number there are arrows on some channels, what are they for? They do not appear to identify grouping or do they.
2 REPLIES 2
MrSL
Leader
Hi @BN , I don't see any arrows on the guide using either my TV via the Telustv-21T stb, android tablet or my PC.
What device are you using when you can see arrows in the TV guide?
Those are 'lookback arrows'. If you put the cursor onto a row that has it, you can press the Rewind arrow button on your remote twice quickly and you should see the cursor move to the channel logo/number itself. Then you can view a list of all programs that aired on that channel up to 30 hours ago.
Type a product name
