1 ReplyReplies sorted by NewestEl-EricCommunity Manager2 years agoHi there Jzman - can you describe your issue?
Related Content[Megathread]: TELUS Connect I have had issues with this app since I started using it ages ago. It's glitchy and almost completely useless. It boasts such amazing features - schedules, device-blocking, content-blocking and...SolvedConnect App - Not connected to Home Network The Connect App no longer works. It says, "You need to be on your home Wi-Fi and enter your admin password to proceed. Please ensure you're connected to your Wi-Fi and reopen the app to try again" ...SolvedEthernet connection Do I need to change a setting for my Telus box to accommodate Ethernet or just hook up the cable SolvedTelus connect app? In Ontario. Just had TELUS PureFibre Internet 1.5GB installed yesterday and everything works (relatively) well however... trying to setup the Telus connect app doesn't. It either says my internet i...SolvedConnected Device I have a tablet with a SIM card slot. Currently I move my SIM card from my phone to the tablet if I want to use the phone functions away from my WiFi. Can I get a second physical SIM card that woul...Solved
Recent DiscussionsTelus Pure Fibre in Ontario - PPPoEHow to use bridge mode on Telus NH20A modemProblem with the terms & conditions on the My Telus appSeeking help with EmailNo WiFi Password Change Option on Connect
