2 Messages
Closed
This isn't really a question, it's just FYI for Ontario (and, I assume, Quebec) customers that have Telus Pure Fibre, delivered on Bell's fibre.
In Ontario, Telus has to use PPPoE. Make sure you get the username & password from the tech or call tech support.
Settings are accessed from Network > WAN, then clicking the Edit button.
Username is in the format of [email protected]
MTU should be set to 1492. No service name is required.
On my modem, I had to enable 802.1q (VLANs) and set the VLAN ID to 40, and the Priority Bit to 0.
You can also check the boxes for the modem to remember these settings even after a factory reset... something the Telus tech apparently did not do.
If you're going to try to get the router to work in bridge mode so you can use your own firewall/router/APs, you will need this information.
Good luck!
Discussion
Updated
3.4K
5
0
Top Contributors
View MoreTELUS_Support
+22 more
Community Manager
8.1K Messages
FuzzyLogic
+25 more
1.8K Messages
Coach
30 Messages
Community Stats
Total Posts
Total Members
Mreid153
I have had zero luck bridging my NH20A to my Flight 2 router. Can't connect by DHCP or PPoE.
I exposed the password field and have my PPoE PW (6 digits?).
Was unable to bridge on either Lan 1 or 10g
6
0
supermario
+1 more
Friendly Neighbour
Using your modem in bridge mode requires more than just your PPPOE credentials in your own router. You'll be getting into some weeds where some of you have not gone before. In a nutshell, you need to tag your PPPOE packets with VLAN 35 before the modem will authenticate you.
I'm using pfsense and the basic steps were as follows:
This will get you online if your modem is in bridge mode (part or full). If you did partial bridge mode, make sure you picked the right port for your cable.
Telus has complicated things a bit further. PPPOE authentication typically uses PAP authentication (older and less secure) but Telus is using CHAP authentication. Problem is pfsense will keep trying PAP for over a minute or so after reboot before switching to CHAP. This is not an issue per se but pfsense will look offline for well over a minute or so before coming to life with a WAN IP. The logs for PPP will tell you the story.
Every router will need to be configured in this way in order to get bridging to work. You can write scripts to force CHAP over PAP but other than the startup delay, there is no real issue.
0
0
supermario
+1 more
Friendly Neighbour
PPPOE authentication from the telus modem to the Bell network is using VLAN 40
PPPOE authentication from your own router to the telus modem uses VLAN 35.
It will not work any other way.
0
0
supermario
+1 more
Friendly Neighbour
To revise my own post, use VLAN 40 and not 35.
0
0
supermario
+1 more
Friendly Neighbour
Also before attempting to use your own router, make sure that the Telus modem and your own router have DIFFERENT DHCP LAN pools. Meaning, they both can't be using 192.168.1.x for the LAN side. Easiest thing to do is change the Telus modem to use 192.168.2.x right off the hop. Chances are this will resolve the issue for many of you who have the rest of the settings correct.
0
0
