Controlling sound bar with Telus remote
Davev16
I have everything hooked up and getting sound from my sound bar but I can’t control it with Telus remote. It says the optic box and speaker are paired and I have turned off my tv speakers. TIA
1 REPLY 1
RobG3987
Advocate
You could try this which worked for me prior :
https://www.telus.com/en/support/article/telus-tv-digital-box-remote
A heads up that it looks like these remote programming won't control the power on/off for the sound bar/audio receiver.
At least it didn't work for me, and I have 2 different locations that I couldn't get to work fully (unlike my old Shaw remote)
