06-12-2013 10:48 AM
Hello, Rogers boasts LTE max and that it is faster than LTE. I understand that it is the network that can handle upto 2600mhz handsets, which I believe at this time, there is only one available, ( samsung galaxy 4 ) Telus has the handset, but does TELUS have sites / regions that are 2600 mhz already in service ? or are we still at 2100 - 2300 mhz ?
06-12-2013 11:43 AM
Rogers has this on there website which shows that the difference is in the theortical maximum download speed.
The reference to the 2600 Mhz is the spectrum band that is used. Rogers has some of this spectrum that it had for a wireless internet project that is no longer used. The maximum speed of LTE is dependant on combining channels and not the spectrum band it is using, the 2600 spectrum has channels tha can be used with the AWS (2100) spectrum to get the 150. The government is planning to auction this spectrum to other carriers in 2014. As you mentioned not all LTE phones can use the 2600 MHz including quite a few from Rogers.
06-14-2013 02:19 AM
Currently TELUS does not have access to the LTE max technology. But honestly, there's not much difference once you reach the LTE speeds. It's all marketing
07-01-2013 06:36 PM
Speed is great..... so is bandwidth consumption. At times, I'm very happy with 3G or 2G.
06-12-2013 11:43 AM
06-14-2013 02:19 AM
07-05-2013 11:38 AM
Speed aside, the advantage is that the 2600 band (Band 7) is being used in other countries, while the AWS band is mostly North American. For example, 2600 is being used in Hong Kong, Singapore and some European countries. If you have 2600-capable phone (SIM-unlocked of course), you'll be able to use LTE in other countries when you travel.
07-01-2013 06:36 PM
