01-07-2024
08:39 PM
- last edited on
01-08-2024
06:17 PM
by
dru
Greetings,
I found out (by accident) that my friend wasn't receiving some text messages, and sometimes they will receive a single message twice.
I tested it by trying to send this message from Google Messages to my other device, which is using Samsung Messages:
<Link removed by Mod for safety reasons>
My first step is find out where the problem is: my sending device, Telus Mobility, or the receiving device. Any suggestions on how to do this?
Thanks,
Shane.
01-08-2024 06:52 PM
A few thoughts:
- Is your friend experiencing this with messages from anyone else?
- On your end, have others reported the same thing with messages from you?
- On your device, have you set a default messenger app?
01-08-2024 08:11 PM
@dru wrote:A few thoughts:
- Is your friend experiencing this with messages from anyone else?I'm not sure.
No. I actually found out by accident.
No. The factory default for the BlackBerry Key2 is Google Messages. I haven't changed it.
01-09-2024 11:39 AM
Have you had issues with coverage lately? Also, has any other contact described similar issues with you?
01-16-2024 08:34 PM
Coverage is bad. I live in Langford (part of Greater Victoria). Signal strength is limited to one bar. No other contact has had similar issues, but I can reproduce the issue. It seems that if there is a link in the message, the entire message gets deleted. So the problem seems to be with Telus and not my device.
01-17-2024 12:20 PM
Is your contact also with TELUS? I would suggest both users to log a ticket with technical support so that the issue can be traced.
Typically outbound messages don't get stripped of content in the event of filtering; it's removed or blocked at the receiving end.
03-03-2024 12:02 AM
Sorry for the delay.
Everyone is on the Telus network.
Telus finally responded and said that that URL is being block for spam reasons.
