September
I'm wondering if the added specification "....when balance falls below $5.00" with the Telus prepaid plan 30-day auto top-ups account payments helps those of us with a $15 a month plan avoid having to regularly monitor/adjust our payments given the limited auto top-up dollar amount choices Telus provides?
September
If I recall, it is a legacy from when there was a per minute fee for minutes, and it would top up if your consumption caused your balance for payment of minutes dropped. I doubt you’ll have success using it in the manner you describe, but you could experiment, and share your results!
I just dropped a $25 coupon every so often, as the excess was carried over.
September
@CAMERC If you pre-set the minimum balance top-up amount ($5) it'll work in conjunction with 30-Day top-up as follows:
If you don't go below a balance of $5 within 30 days, the account is topped up via the 30-Day Top-up.
If you go below $5 within the 30 days, then Minimum Balance Top-up is used.
So you've got two options working in the background at all times to ensure continuity. I hope this answers your question.
