Long distance incoming calls
Nikkol
I was just wonering if i can accept long distance calls. I constantly have these numbers from malasia calling be and its really annoying a frustrating. I cant block the number because they call from a different one every time. I was just wondering if i am at home in my call region and they call me, call i amswer and tell them to leave me alone without aquiring long distance charges? My dad says i can but i just want to double check because i dont think hes correct. Any help would be much appreciated
No. There are no long distance charges when receiving a call in your home area (province-wide or nation-wide), no matter where the caller is located.
3 REPLIES 3
WestCoasterBC
Don’t answer the call, it will tell the robo dialer it’s a good number, and will only make it worse.
Would it be a long distance charge tho? And i appreciate it i wont answer it!
