07-11-2013 05:39 PM
something is wrong with my internet, I keep getting this message when browsing on sites.
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache Server at www.gamefaqs.com Port 3128 its not just that site, its any site. I had this hub for at least a month now and it just started happening, i have another problem with it but ill make another topic after
09-11-2013 10:32 AM
I'm afraid it'll be time for you to contact TELUS technical assistance. 1-866-558-2273. Good luck with this !
07-12-2013 07:51 AM
Have you tried resetting your hub, unplug/replug and rebooting your computer?
Also, what are the signal light colors under MODE (should be blue,green or orange), WIRELESS (should be solid blue) and WIRELINE (should not be lit)?
07-13-2013 05:28 PM
restarted the hub a few times and it helps for awhile than it happens again, but i never turned the computer for awhile and i never seen the message yet, lets see how long this lasts
07-13-2013 06:16 PM
Do you have any other TELUS devices? How do they tend to work? Strong signal?
After restarting the hub, should the issue persist I'd encourage you to contact us at 1-866-558-2273. We will need to get specific information from you regarding your account, location, set-up, etc.
09-05-2013 04:49 PM
yeah the problem is persisting, reseting the hub use to work but not anymore. this sucks
09-11-2013 10:32 AM
