no wifi connection
Reply
Highlighted
Resident
ever since i've had my iPhone 4 it doesn't find any wifi signals, whether home, at work or at startbucks for instance, nothing ever pops up.  I've tried, rebooting. reseting network, reseting the whole phone, turning wifi on and off (everything Apple support says to do) and nothing has worked.  Any ideas?
Accepted Solutions
Highlighted
Most Helpful
In Settings > Wi-Fi, Wi-Fi must be on, and Ask to Join Networks must be on.
The networks you are trying to connect to must be broadcasting their SSID, else they will not be visible to you, and not discoverable to your phone.
All Replies
Highlighted
Most Helpful
