11-03-2018 04:36 AM
I use iphone 8 to upgrade to ios12 operating system but see people say it is very expensive battery? is not that so
11-03-2018 12:12 PM - edited 11-03-2018 12:12 PM
I wouldn’t be concerned about your battery. You’ll long upgrade before the battery drain is so extreme you will need to replace it.
iOS 12 will enable throttling but most people upgrade every 1-3 years. Even if throttled eventually your phone is still more then operative slowed down.
I’d imagine there will be pushback to totally turn off the feature in time anyways.
Battery replacement is fairly cheap even from Apple.
11-12-2018 02:32 AM
Yeah true. Replace your battery at low price before its offer goes end. You just have to visit an apple store and there you go with new battery. Go and Replace. Enjoy.
