09-17-2021 04:07 PM
09-18-2021 02:27 AM
What do you mean by blocked? What does your mother hear on her end when she calls?
Does your phone show a missed call or nothing at all?
09-18-2021 05:46 AM
09-18-2021 09:37 AM
Hi there!
Is your mother's number the only one that gets blocked?
Have you tried to remove the number from the contacts list and re-add it?
09-18-2021 10:44 AM
09-18-2021 10:46 AM
09-18-2021 11:06 AM
09-18-2021 02:04 PM
You mentioned the problem is recent. There was an OS update from Samsung that started rolling out Sept 6. It's possible there is a bug in the update.
09-18-2021 01:58 PM - edited 09-18-2021 02:01 PM
@T-Speed has the fix. There is a glitch in your contacts on your phone. Remove her contact entirely and create it again.
[Edit] Disregard the above. I didn't scroll down to see your other messages.
