PLEASE HELP NETWORK UNLOCK CODE
Unhingedpirate
Network unlock code please there has to be someone out there that has asked and has this code ???
2 REPLIES 2
Fabylous
Community Manager
Community Manager
Hi @Unhingedpirate  are you referring to the code to unlock your device?
BoaGuy
Community Manager
Community Manager
Hi @Unhingedpirate
Check if your device is already unlocked
  1. Place the activated SIM card you’re looking to use with the device inside of the phone
  2. If the device says that you have an “Invalid SIM “ or “Network Unlock PIN”, you may need to unlock it
Note: If your device does need to be unlocked, please use our virtual assistant and ask for “unlock my phone”.
Hope this helps.
