Unhingedpirate's avatar
3 years ago
Solved
PLEASE HELP NETWORK UNLOCK CODE
Network unlock code please there has to be someone out there that has asked and has this code ???
  • BoaGuy's avatar
    3 years ago
    Hi Unhingedpirate
    Check if your device is already unlocked
    1. Place the activated SIM card you’re looking to use with the device inside of the phone
    2. If the device says that you have an “Invalid SIM “ or “Network Unlock PIN”, you may need to unlock it
    Note: If your device does need to be unlocked, please use our virtual assistant and ask for “unlock my phone”.
    Hope this helps.
