How to print out text messages android?
gadzxcv
There are a number of Apps on the Google Play store to accomplish this task. One recommended is  SMS Backup Plus, which will allow you to review and print texts from a Gmail account.
Also, a web search will likely turn up a sizeable list of options.
2 REPLIES 2
Rwaahby
If you just need to save/ print text messages .You can do simple screen capture . Simultaneously press 'power' and 'volume down' buttons to capture the screen. Then, you can save or share the image, or even print it out
