Hi, you can try these codes as well. Activate: *21* + area code + phone number + # + SEND Deactivate: #21# + SEND
**Note: Make sure that call forwarding is part of your plan because if not then the minutes per call forward will be deducted on the minutes of your plan, LD or Local. Also if you ran out of minutes you'll be charged of the overage rate per minute.
