09-16-2013 12:52 AM
09-16-2013 09:03 AM
Make sure you also regularly close your background apps. If you're using an iphone, double tap home button to see list of opened apps, than press and hold on the apps to close them. Very often if your phone disconnects from wifi for whatever reason, it'll automatically connect to cellular network and won't always go back to wifi. To be safe, you can always disable cellular data from your mobile network settings, it'll still allow calls/text/wifi
09-16-2013 02:07 AM
Some thoughts...
09-16-2013 09:03 AM
