Drive+ error code removal.
Bustamatic
Anyone know if there is a way to clear error codes with the Drive+ after the repair is completed? I completed the repair 3 days ago but still get the error code every time I start the car.
Is it Drive+ or was the error not reset from the car's computer after repairs were completed? If your car was repaired by a shop, they should have reset the code on the computer.
1 REPLY 1
