Cibc Tap and pay
Reply
Matt64
Friendly Neighbour
Accepted Solutions
Most Helpful
Guardian
CIBC mobile payment supported phones are on the CIBC web site. I suggest you contact CIBC to see if and when they will support your phone.
https://www.cibc.com/ca/features/mobile-payment.html
All Replies
Dimo-X
Moderator
Moderator
Hey Matt! As it is available on many of the Samsung platforms, I imagine it should be in the works! Keep tabs on the TELUS site 🙂
Guardian
Try downloading the app to see if it recognizes your hardware. I believe the Note 4 comes with the NFC SIM already.
Matt64
Friendly Neighbour
Matt64
Friendly Neighbour
It says it's not compatible with my device, I tried to post a screen shot but it didn't work
Matt64
Friendly Neighbour
Matt64
Friendly Neighbour
Where on the Telus site would this be posted when it it available?
Most Helpful
Guardian
