Changing phones??
Karnold618
I am on year 2 of my 3 year contract with my iPhone. It says I can upgrade now... I want to upgrade I a galaxy S4 and wondering if I can do that? And if so how much would that be?
1 REPLY 1
Silver_Arrow
Ambassador
Do you mean starting your second year or ending your second year with it. If ending the upgrade wlil be one third the discount on the iPhone (Which i believe is 500/36 *12) which is $16. If you are starting year two then it is $332. Then you pay the two year price of the S4 which is  $200. The you add tax so it would be at least $400 for you to upgrade to the S4 assuming you are endign year two and starting year three and Almost $600 to upgrade if you are just starting year two.
