March
so during install of fiber optics my printer turned off and eventually back on. installer didn't check before leaving and I didn't either until I actually needed to print stuff. Anyway it is connected via cable and not setup for wifi and now I get an error window saying no device found or check wifi connection. Again it is via cable. I called the installer as she said to if I have any problems but she is not responding I've left two msgs since March 1. any suggestions on how to get the printer to work I've followed the check list in the pop ups. nadah
March
Sounds like your issues are between your computer and the printer. The switch to fibre has nothing to do with that. The default printer is a setting on your computer. Some applications will go print to the default printer automatically other applications may not select the default printer automatically. These are not issues the Telus service technician is responsible for.
Having said that, you may still be able to get some help here from the Neighborhood members but you need to be more specific about what you are doing and what you are seeing. You won't get specific help unless you provide specific details.
March
Do you still have the same Telus gateway/router as before or was it replaced?
March
Same router
March
It's likely the IP address changed after the power reset. Your computer is probably trying to connect to it via the old IP address. Reinstalling the printer software might get things working again.
March
I don't know how, my nephew set me up and he is no longer available. 😞
March
Cable from your computer to the printer, or from your router to your printer?
March
not sure my nephew installed it for me however he no longer is near me. I will have to check thanks. Nothing was disconnected.
March
update on data, so the printer is connected but isn't working correctly. I found the printer troubleshooting and it said printer wasn't dedicated as default so I followed prompt to fix it. Printer successfully printed a test page and two word docs however later when I tried to print attachments/downloads from emails in pdf format it would not print. I went back to troubleshooting and it said nothing was wrong. So whereas this printer worked on ALL types of documents now it appears to be selective. This is just since the update to fiber optics. Very disappointed that Telus installer is not returning my calls when they said "if any problems please call me". I have a class coming up tomorrow (Thursday that I need these docs printed for) any help appreciated. I have limited computer knowledge and counted on my nephew who is no longer available to help.
March
When printing there should be an option to select what to print to. For the files that aren't working check to see if there is possibly more than one printer listed and try a different one.
March
March
March
