Peppercat
5 years agoFriendly Neighbour
printer not working after fiber installed
so during install of fiber optics my printer turned off and eventually back on. installer didn't check before leaving and I didn't either until I actually needed to print stuff. Anyway it is connect...
- 5 years ago
Sounds like your issues are between your computer and the printer. The switch to fibre has nothing to do with that. The default printer is a setting on your computer. Some applications will go print to the default printer automatically other applications may not select the default printer automatically. These are not issues the Telus service technician is responsible for.
Having said that, you may still be able to get some help here from the Neighborhood members but you need to be more specific about what you are doing and what you are seeing. You won't get specific help unless you provide specific details.
- What type of computer are you using, Windows, Mac, Chromebook?
- What is the printer brand/model?
- What application were you using when printing worked?
- What application were you using when printing didn't work?
- What does the print screen show as the selected printer in both cases?
FuzzyLogic
5 years agoIt's likely the IP address changed after the power reset. Your computer is probably trying to connect to it via the old IP address. Reinstalling the printer software might get things working again.
Peppercat
I don't know how, my nephew set me up and he is no longer available. 😞
