Peppercat
5 years agoFriendly Neighbour
printer not working after fiber installed
so during install of fiber optics my printer turned off and eventually back on. installer didn't check before leaving and I didn't either until I actually needed to print stuff. Anyway it is connect...
- 5 years ago
Sounds like your issues are between your computer and the printer. The switch to fibre has nothing to do with that. The default printer is a setting on your computer. Some applications will go print to the default printer automatically other applications may not select the default printer automatically. These are not issues the Telus service technician is responsible for.
Having said that, you may still be able to get some help here from the Neighborhood members but you need to be more specific about what you are doing and what you are seeing. You won't get specific help unless you provide specific details.
- What type of computer are you using, Windows, Mac, Chromebook?
- What is the printer brand/model?
- What application were you using when printing worked?
- What application were you using when printing didn't work?
- What does the print screen show as the selected printer in both cases?
Peppercat
update on data, so the printer is connected but isn't working correctly. I found the printer troubleshooting and it said printer wasn't dedicated as default so I followed prompt to fix it. Printer successfully printed a test page and two word docs however later when I tried to print attachments/downloads from emails in pdf format it would not print. I went back to troubleshooting and it said nothing was wrong. So whereas this printer worked on ALL types of documents now it appears to be selective. This is just since the update to fiber optics. Very disappointed that Telus installer is not returning my calls when they said "if any problems please call me". I have a class coming up tomorrow (Thursday that I need these docs printed for) any help appreciated. I have limited computer knowledge and counted on my nephew who is no longer available to help.
FuzzyLogic
5 years agoWhen printing there should be an option to select what to print to. For the files that aren't working check to see if there is possibly more than one printer listed and try a different one.
- Peppercat5 years agoFriendly Neighbourthanks, however I only have one printer installed.
