04-08-2020 04:34 PM
Hi,
I have a new TELUS wifi hub connected to Internet on Fiber in my House.
I want to use my old T3200M in my Garage like a wifi extender, so all devices will be on the same network as the House.
There is an ethernet cable between House and Garage.
How do I setup the T3200M to expand wifi hub's network so all devices are on the same network?
D-Man
04-08-2020 06:39 PM
It might be simpler to purchase an inexpensive router designed for this.
You can try turning off NAT and DHCP on the T3200M to see if you have success.
04-08-2020 06:39 PM
