D-Man
6 years agoNeighbour
Wired Ethernet Connection between a TELUS wifi hub and a T3200M to expand wifi hub's network range
Hi, I have a new TELUS wifi hub connected to Internet on Fiber in my House. I want to use my old T3200M in my Garage like a wifi extender, so all devices will be on the same network as the Ho...
- 6 years ago
It might be simpler to purchase an inexpensive router designed for this.
You can try turning off NAT and DHCP on the T3200M to see if you have success.
6 years agoIt might be simpler to purchase an inexpensive router designed for this.
