July
July
The conduit is open at both ends. If the end in your house is lower than that at the street, and the water table is high enough, you can get you could get water at your house. You could get some plumbers putty at the hardware store, and plug the end of the pipe.
July
July
July
@Riverbend9 Most of western Canada is in a drought. Yes the pipes will fill with water cables are good for direct burial. Search your yard for an unusual green area in lawn you might find it. Call town city and they should come and check for a leak. May end up in your basement.
July
